Corner light out intermittently?
Holidazed
Car: 2001 Nissan Pathfinder SE
So I installed HIDs in my pathfinder 2 days ago, and I'm not sure if this is related or not but...since then, my passenger side corner light has been out when I first start up the truck. if I tap on the light from the outside it goes back on and stays on fine. But I dont want to have to get out and hit my light everyday.
Could this be related to the HID installation or just a coincidence? or is this an indication that a bulb is going bad? wiring problem? loose wires?
please help, thanks!
volp
Car: 99 Infiniti QX4
I noticed with my corner light that if the bulb isn't in just the right way then it goes out sometimes. I think it has something to do with the contact points since it is a wedge type bulb. You can try replacing the bulb seeing as they are all of $4 a pop. Otherwise you'll just have to play with it. I don't see how it could be related to the HID's
Holidazed
is it easy to replace the corner light bulb? how do i take out the corner light?
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Nope, I have the exact same issue as you, and no HID upgrade.
Probably just a bad bulb.
