Axoure Dragonkin »
https://forums.nicoclub.com/axoure-dragonkin-u19649.html
Thu Apr 14, 2011 1:09 am
On my s13, I just got a corner balance, ride height adjustment, and race alignment (currently set for road racing because it's my DD). we also factored in weight. car handles awesome and is now sitting straight
The preloads they introduced on my car confound me a bit. Most noticeably, pass front and rear.
Passenger front is set extremely tight, I hear the spring jump when turning at low speeds (it is greased).
Passenger rear worries me a bit. It is negative loaded by 3/4 inch or so. When the car is jacked on that side there is 3/4 inch between the spring and the perch.
is this normal?
i ask because coilovers came with instructions not to adjust ride height by lowering the spring perches
according to the scales pass rear was lightest corner by 80 pounds with full tank of gas, even with my battery relocated. my battery is relocated next to pass wheel well, over the axle, if that makes sense.
