Core Motor Mount Question
mikalkouki
I just pulled my rb25det out of my s14 that was installed with a core motor mount kit and one of the seemingly design-flawed bushings on the motor mount ripped apart.....
Does anyone know of an interchangeable replacement (parts store available) or even better an upgrade replacement for this part?
smitty4130
Car: 95' S14 w/RB20DET, 03' BMW 330Ci
Can you show a picture and take measurements of the bushing?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I was actually working on making polyurethane replacement bushings for these mounts since the isolators are junk and lots of people have had them fail/rip. Luckily mine haven't, but I still don't trust them.
Would you be interested in being a guinea pig?
mikalkouki
smitty4130 wrote:Can you show a picture and take measurements of the bushing?
the isolator itself from plate to plate is 2" long and the width of the octagon shaped plate is 2.75" wide as well as the circle shaped plate that ripped off.
mikalkouki
Darius wrote:I was actually working on making polyurethane replacement bushings for these mounts since the isolators are junk and lots of people have had them fail/rip. Luckily mine haven't, but I still don't trust them.
I would definitely be willing to test out your design as I was an autoglass tech for some years and I know the potential shear strength of modern polyurethane. If I remember correctly, when surfaces are primed properly, a tensil strength around 1200lbs. per sq. in. The only thing is, I have a 2 week deadline to get the car back together.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Maybe hockey pucks will work, they just need a hole drilled. Search for it lots of people are running them. I'm running on solid motor mounts at the moment, a bit rough at idle but it really smooths up when moving and acceleration. You can feel everything, wouldn't recommend it without strut tower braces and stitch welding though.
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
Man, I'm using these mounts. No problem so far, but I got it tuned up in January and it makes a little more power now.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I am getting some polyurethane bushings for those made up to test out soon. on my s13
Neejay
Anchor Engine MountPart No. 2381
Advanced Auto parts: part #2381
this is why they break apart: $10
http://shop.advanceautoparts.c...S____
Another reason why I'm glad I went with the ruckus-racing mounts
Darius
Good find. That would make sense for why they fail so frequently. $10...
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
poly is great, but just to offer another option, I'm using hockey pucks with mckinney style mounts. Not sure how these mounts compare to these "core mounts" but the strength of Yugoslavian rubber pucks has held up without any issues on a stock rb25 for more than a year now. plus the motor sits a little lower than what the McKinney poly ones allow.
sean8564
1993 Nissan Silvia
Do you have any sway bar issues with it rubbing on your oil pan??
mischiefmounts
madcowvert
zer...age=1
this was my thread that i did a long time ago and it might help out. I had a friend make me some . They are made of polyurethane and aircraft grade aluminum they worked great for me.
