Copper Spray on Cometic exhaust gasket (do or dont?)
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
So I'm about to install a metal cometic exhaust gasket. Do you guys recommend spraying it with copper or installing it as is.
-Daryl
chad b.
Car: chocolate chip kouki
I always have, and never had an issue. It can't hurt.
StricNyne
i spray that s*** on everything, and the permetex s*** on every other gasket
silviasgp06
ok, cool. Thanks guys
RRRRB
Car: 98 RB powered S14
ive done it both ways and havent noticed anything different
Ramius83
Car: 1995 240sx SE
I have a general rule of thumb when it comes to the use of Permatex Copper Spray.
When I have had the engine block and head decked, I will not use it as it should not be needed.
When I have just taken the head off to do a head gasket, then yes, I use it.
I too have done it either way, with no obvious difference in results. But a perfectly level and clean head/block should not need it.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
