White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Thu Aug 20, 2009 6:46 pm
like the title says i have a few mystery wires and a few plugs to figure out as well. well tidying up my wiring squid i came across a few wires that were cut and leading to nothing. theres a good chance i don't need these but i'd like to get some input (i'm counting on MGE to stop in). all the cut wires were found behind the fuse block behind the kick panel on the driver side. i traced the wires back as far as i could for the night and i have a breakdown and pics of everything.
first up we have a yellow wire with a red stripe. the wire goes to the small plug pictured below. somewhere under the driver side small under dash panel. the other wire on the plug is black and is therefore a ground, so thats not too helpful
next we have a red wire with a black stripe. as previously mentioned this wire (like all of them) started behind the fuse block and led up along the harness to where it branched into several wires of the same color. one of those red/black wires goes to another small plug found in the same vicinity of the first plug but nearer to the steering column. the other wire to the plug is green/white and is also cut, pictures below
the 3rd wire is solid red and goes to one of the long flat plugs that is used for one of the buttons near the instrument cluster (iirc)
the last wires all just lead up the harness and presumably across the dash. they are; yellow/blue, yellow/green, blue, green and red/black. theres a good chance that the green wire and possibly some of the others goes to the door dinger. i'm gonna hit fsm like i'm studying for the SATs but i appreciate any help, thank you.
Modified by White Comet at 10:13 AM 8/21/2009
