krayton »
https://forums.nicoclub.com/krayton-u8223.html
Thu Sep 28, 2006 8:36 am
carl, im doing the same. well attempting. just wanna try it.
if funds let me, im taking measurements of a radiator thatll fit under the radiator support. i want it to slide all the way forward like the stock condensor is.
if i dont have cash for a custom sized radiator, then im cutting the top off my koyo filler kneck off and cutting th e bottom to jam it in there. either way im adding a expansion tank high above the engine to fill the coolant. i do have the stock radiator support cut, but that wont allow enough room for the clutch fan.
im just gonna attempt to barely clear the clutch fan then secure the radiator in there. then build a nice custom shroud.
fyi, those custom sized radiators can be picked up anywhere (ie griffen)
edit:
this is what i wanna do. this is an awesome build from a guy on ziptied. i talked to him and hes using a friends SR from a s13. he said he just jammed it in there.
