nice!! sounds good.zach-Ka wrote:They are not worth $100 make your own. I made mine for $15
lol, thanks for the tipzach-Ka wrote:Just make sure to measure, then measure again, then once more...
Im gonna wait on that till i do my SR swap. but yea, thats the plan.ILoveMyRHS13 wrote:Get an aluminum radiator, such as a Mishimoto or Koyo, etc.
i honestly didnt even think about that. thanks for the tip.breaker77 wrote:an oil cooler will help you tons.
probably bring your engine temps down more then 15 degrees
as opposed to upgrading the rad and getting electric fans?richiev8s13 wrote:if i was to do it over agian i would run stock clutch fan with fan shroud and stock rad it the best thing for it its not going to stop not working in less ur motor locks up
I'd probably do the radiator. But the clutch fan I think works well. It's always spinning and failure rate seems fairly low. Instead of spending the money on E-fans, I'd get one of those cheap oil coolers from summit racing.discoballer wrote:
