dirtylarry wrote:...i smelled burning coolant and saw little smoke, so now im pissed i pop the hood and i see coolant on the top of the radiator and the place it was coming from was the little hose on the top of the radiator that leads to the coolant resevoir ...
so i let the car cool down and i checked the radiator and it was still full but i did notice that the resevoir coolant level did go down a little so after a few hours i drove the car back home it did not overheat but some more coolant leaked out of the same hose,
so after this long explaination i was wondering do any of you on here have and suggestion as to why i am having these problems with the cooling system and i will not be driving the car again until i get it looked at because i dont want to blow another radiator and do u have any suggestions to a good shop in the Atl that i can take it to or should i take it the the stealership, i really want to get this solved once and for all, so thanks in advance to any help , and i apoligize for being longwinded to explain
From you description, it sounds like you already found the problem. It is common for that hose to leak because it will stretch and not fit properly anymore. The last time you replaced the rad, more than likely they didn't replace the hose that goes to the overfill tank.
If i was repairing your car, i'd let it heat up, build pressure, and take a look where it is dripping from, to confirm the problem. If it is the hose, then repair it, and do a pressure test on the rad, and cap to show you it holds.
I don't live in atlanta, so i can't recommend a shop for you. Take it back to the shop that did the rad. see if the'll show you what the're going to do.
