elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Mar 11, 2006 3:51 pm
Heres what I do, this shoudl work great for you.
BUY: A few gallons (4-5) of distilled water from wally world, a new Tstat from Joe, some RTV, and some AF.
1. Remove your Tstat2. plug everything back in (with Tstat out)3. drain the radiator4. Fill the radiator with water5. Start car for a few minutes, or even more ideally you could rig something to the water pump so you didnt have to run the engine... regardless, run the engine for a minute or 26. drain the radiator7. repeat steps 3-6 until you get clear water coming out.8. After the final drain, replace the Tstat, and then fill the radiator up with 100% anti freeze, this will give you about 70/30 mix, which is a good mix...
Or you can do what Dale suggested and use the garden hose method which probably works equally well.....
BTW dont use the radiator drain, just take the lower radiator hose off, makes things go much faster.
