book-ends »
https://forums.nicoclub.com/book-ends-u3879.html
Wed Dec 08, 2004 2:09 pm
Hello all,
I did a search for water pump related posts, but I didn't quite see what I was looking for. Over the last few days I have replaced both upper and lower radiator hoses, thermostat and radiator (just did that today). The car was overheating at idle and coolant was going everywhere from a crack in the radiator.
So now that everything is together, the car is still overheating at idle!! If you rev the motor to about 4000 PRM, the coolant temp drops immediately which leads me to believe that it's the water pump......
Can that be right? If the water pump is failing, why would it just be at idle? Blasting down the highway at speed isn't a problem at all so I can assume the fluid is moving through the system......
Any insight by early tomorrow morning would be greatly appreciated!
P.S. - I have a 91 240 KA24DE
