DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Nov 01, 2004 10:20 am
The pump is what the radiator fan is attached to in the front of the engine, but I don't think it matters. The coolant does not go directly from the pump to the heater core. It might come from the head and go to the block or something like that. Look for 2 heater hoses running through the firewall and trace them back, then just connect the sources. Better yet, track down a FSM and look at the coolant routing diagram. That'll be a short term fix. I'm sure you'll want heat, even in SoCal.
