So I was going through and doing some routine maint. today you know checking at the fluid levels, and I pull the rad cap off and the coolant has like rust? floating in it? I don't think it's oil because it's not milky/white/brownish. It's redish brown and almost looks flaky I guess you could say. Any ideas? I mean I know our block are made out of rust aka iron, but any ideas if it might be coming from somewhere else like a water pump that's about to fail or a rusted out turbo from the waterlines, or ???? Not sure if this is normal or should I be concerned? (I mean I don't think I've really run across this so far but maybe it's just something that happens with CA's. I have had that water in there before(can't remember the name I think distilled water?) But that was when I ran into trouble with coolant awhile ago, but have since then switched back to coolant.
