bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Tue Dec 19, 2006 3:35 pm
So one day out of the blue I glance down at my gauges and the temp was like 90% of the way to the line indicating the start of the hot range. This startled me and as I was watching it fell back down to normal. Over the next couple min it did it a few more times, going from normal to almost hot and back, in about 20-30 second cycles. I opened the radiator and it was way low so I topped it off and it stopped doing this. Since then I have noticed a decent puddle under the car every time I get in (more under the driver’s side), so I know it is leaking. I believe it is the water pump, and I plan to change it out in about a week. I am just curious as to what exactly was going on to make it register hot and then drop back down? Air/steam trapped at the thermostat or what?
I am confused here, I thought the overflow reservoir was supposed to drain into the radiator. But it seems like the overflow is only periodically draining. Sometimes the overflow will be low and I add water to it, other times the overflow is full but the radiator is still low. Any thoughts on this?
Thanks!
