wait...just caught that. so you see over 50% on your stock gauge? are you using a stock aftermarket?RB20DETodd wrote:Well ever since i installed the front mount i have been having a cooling problem i know the fmic is blocking air but whats going on under the hood is odd, it never gets pegged out just like 80% on the gauge, when i pop the hood my coolant resivor is full and venting all over the ground, any ideas, i bled the system last night, no air in it maybe my thermostat doesnt like my fmic?
Thanks,
-Todd
MISTAKE!you should always take off the water pump to atleast inspect it and ALWAYS replace the thermostat!thermostats are cheap insurance and they can go bad at anytime, spend the 14$ at the dealer for a z32 TT stat.RB20DETodd wrote:Right now im using the stock Ka radiator with 2 10 inch puller fans that run all the time, i havent replaced the water pump or the thermostat yet, im thinking about changing fans to 2 12'' fans if i can fit them that pull some crazy cfms and a koyo oem replacement radiator, i dont think my thermostat or my waterpump is the problem. When i bled the system i started the car let it run for a min then poped the radiator cap along wit the plug in the intake manifold and waited till i had straight coolant comming out of the burp hole. Im gonna try this process again tonight after work, let me ask you guys this, i was able to run puller fans would adding a 14'' pusher infront of the condensor help out?Any fan recomendations?
Thanks
I probobly would have replaced it but when i got the motor the waterpump had a crapload of rtv coming out it and looked "newer" than the motor, and was straped for cash at the time of the swap, i wish i could have replaced the waterpump, thermostat, and clutch the clutch replacement is gonna be a whore to do now, but im gonna change out the thermo in a week when i get the new koyo copper core radiator, what year 300ztt thermostat will work?Carl H wrote:MISTAKE!you should always take off the water pump to atleast inspect it and ALWAYS replace the thermostat!thermostats are cheap insurance and they can go bad at anytime, spend the 14$ at the dealer for a z32 TT stat.
