johndavid400 »
https://forums.nicoclub.com/johndavid400-u12698.html
Fri Jan 28, 2005 1:33 pm
OK, so I have been noticing a slight leak from my car in the garage over the last week. It is just about a tablespoon or two of coolant that leaks out after each night. Today, the 'check engine' light came on, and then it started heating up (the temp. gauge went almost to the red). So I check the coolant level and it is about 2" from the top, but completely covering the radiator fins inside the radiator, so I head over to get the code checked at autozone and it says "check coolant level". Now while I was driving through town, it would start to heat up, but as soon as I hit the interstate and began going 60-70mph, the temp gauge went way down to the normal operating range.
I was thinking that the problem has to do with one of two things. Either the water pump or the thermostat (since when I briefly looked, I saw no cracked or leaking hoses... and it hasn't been below 40 degrees this month). I thought it might be the water pump or maybe just the gasket on the water pump. Since when I start pushing higher RPM's, it starts pumping the coolant and the temp goes down. I do not have the time right now to go outside and get under the car to check everything (I am 1.5 hrs away from my house, visiting a friend and have no jack or tools with me), but does this sound like a probable cause, given the symptoms? When I get home Sunday, I am going to do a full inspection and replace whatever is necessary, so what do you guys think it might be?
Also, Is the water pump on this car driven by the timing chain or the fan belt pulleys? On some of my other cars, it was on the timing belt, but my Chilton manual says that it is on the fan belt pulleys on the Altima but it didn't say for the 240sx (I know they are the same engine, so I'm guessing that is the same also).
Any help is GREATLY appreciated! thanks in advance
