onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Wed Sep 14, 2005 7:42 am
From the performance loss perspective:
Removing the clutch fan free's up lost hp, etc.
However, if you wire electric fans to ignition, they are now always on, which increases load on the alternator - I don't know about aftermarket ones, but my altimas took quite a bit to power. -> hp gained is now lost, basically more or less.
The purpose of changing to electric fans is that your don't need fans running all the time. The hp benefit comes in when they are off.
If you look on altimas, or any car that has electric fans - they shouldn't be running all the time. If you do let them run all the time, they will break down much faster - a lot of members on zilvia & here have complained about elec fans - however, most of these complaints of the fans breaking was because they had them wired to ignition - some never have this problem though, so it may have to do w/ how long/often you drive w/ fans running, iono.
From the cooling perspective:Perhaps I was using the wrong terminology. This is what I noticed:
Plug in my fans (both wired to one - so both fans on the altima were on) to ignition.
Car starts. Water temp gauge will not move up past 1/5-1/4 of the gauge. Car smells rich all the time, probably since it's stuck in "cold mode". Especially once you get on the freeway, temp goes down even more - this was mostly the radiator capabilities I believe.
In any case. Tried the same test w/ the fans off -> temp rises like it should. I was thinking I could have a thermostat leak (new thermostat), but it would have to be very miniscule or the car wouldn't warm up at all, even w/ the fans off -> which means the fans did have some effect on this.
Maybe, and I'm just speaking out of my *** here, the coolant from the lower radiator hose flows back and forth between the radiator and water pump - this way there wouldn't be a dramatic difference in temperature between the fluid in the radiator and the fluid in the engine block, but at a much slower pace than if the upper radiator hose started flowing. With that theory then, it would make sense that the altima fans could have flowed so well, that it kept the engine coolant from getting warm enough.
