C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed May 19, 2004 1:19 pm
In a v-mount set-up, separate ducting would be somewhat negligible. As long as the sides are blocked off to effectively make a single duct that feeds to both units, it should create enough of a high pressure area in front of both to make it reasonably effective. However, there can be a lot of factors depending on the set-up, the car, the amount of effectiveness you want out of both the radiator and the intercooler, etc.
