wannawangan wrote:Here is the concept summed up in text/graphic:
Air Filter -> 1st I/C -> MAFS/Turbo inlet -> Compressor outlet -> 2nd I/C -> Throttle body/engine
Would this set up cool the incoming charge better than a large, single I/C?
Please assume that you are taking an assumed efficient I/C, split it in 70/30, 60/40 or 50/50 sections and mounting the respective pieces in places where air flow is common place (i.e. vented wheel well, front fascia, hood scoop, etc.)
Your first intercooler comes right before the MAFS. Yes good idea to cool the charge, before MAFS to fool your ECU.
BUT.
You can avoid 1st intercooler by drawing cold air in the first place. Just create a ram style air system that gets air from outside(below or front)
Problem with 1st intercooler is added restriction, pressure drop, space, and inefficiency.(becuase air sucked in is already cool enough, if drawn from outside.)
Assuming 14.7 atmospheric pressure, and assuming it as a zero at 1 bar of boost, meaning no boost. There is no such thing as pressure drop, but can call it a negative pressure or vacuum. Meaning, a restriction.
So it is a bad idea, but thanks for trying.
Modified by sanioll at 7:45 PM 6/22/2005
