def. to much overkill. you don't want to have to much clutter in that area because even if you have a fan, it is still going to disrupt your airflow. so there is a pretty good chance it would actually decrease the cooling efficiency.Rosco wrote:So I'm throwing around this idea: What if I put a small fan mounted to the back of a FMIC? The theory is; It will pull air through the intercooler to the radiator which in turn will get pulled through (Air that is) by the fans on the backside of the rad. Overkill? Could doing this be beneficial? I haven't heard anyone else doing this, so does that mean it's really worth it? Obviously the reasoning behind doing this is to keep the rad nice and cool. As we all know the cooler the air moving through the engine the more happy the car is....So what do you guys think?
That pretty much settles it for me right there. Thanks, I was a little too excited that I had an idea that might work that I totally didn't think about that.karmakaze wrote:
besides when you are driving down the road you are actually getting more airflow than an electric fan can pull so its pretty much pointless.
You mean a water intercooler?karmakaze wrote:what i want to see is a fmic that also has water lines ran through it that circulates water to a reservoir that is cooled from peltier heaters. ...
i guess since i just publicly posted that i will go ahead and build one so i can register it.
you can get peltier heaters rated to cool into the negative numbers. nuff said.RichthePoser wrote:You mean a water intercooler?
The subaru community has been over this topic many man y many times. The basic theory is:
A fan will pull air over the IC at such a CFM. most of the time (while driving) you are already outdoing the fans by just driving... so when would they be in a benefit? At a stop/start race (ie. traffic), if you need those extra 3Hp while your next in line at the toll booth.
Pointless on a FMIC with driect airflow. A fender mounted IC, I could see having some use, but limited.
Rich
