Really? From Joe?BLACKonBLACK98 wrote:even the mack daddy kit doesn't contain all of them anymore. 1 hose is unavailable.
Why it is suggested to get the mac-daddy kit and replace ALL hoses/KS at the same time.....you are getting ready to remove your plenum for the 4th time because you didnt follow this advice!!!!! In 216,000 miles,my plenum was removed ONCE, and everything replaced{at about 200k},should never need to be removed again under my ownership.breaksr wrote:I'm fully educated in removing / re-installing the plenum. I've had mine off three times and I've had a friends off once so I know about the hoses being brittle. I'm just wondering if there were any other cooling hoses that are under the plenum that I might miss besides those two larger ones that are above the knock sensors. I can't tell if they are leaking but there is some fluid coming from somewhere so it seems those two hoses are the most likely candidate. I just don't want to remove / install the plenum more then once. All of the emissions hoses are still in good shape I replaced a couple of them years ago.
What else can you get for $1,500? $3,000? $12,000?breaksr wrote: The car runs great and I really don't feel like paying $40+ for one breather hose. I've found that you have to go easy on the amount you spend on this car given the vehicle is probably only worth about $1500 at best.
coorect. i was told "INF 11826-67U15, hose blow by, a" was no longer available and received a refund for that part.maxnix wrote:Really? From Joe?
