cooling help
silvia-junkie
Car: s14 kouki
after driving my radiator system is not presurized. you can squeeze the radator hosess easly. i did just replace the waterpump could that be it? i also believe that the turbo coolant line is leaking a bit during a pressure test i loose about a pound of pressure a min but wouldnt that just depressurize me quicker not prevent me from bulding pressure
thx for any and all help
SpeedRacer1
Car: 1990 240SX, G35
There is nothing wrong with being able to squeeze the radiator hoses. Unless you have an aftermarket temp gauge and notice heat spikes I wouldnt get worried.
180fan
Car: 89 fastback
You've probably got air bubbles trapped in your cooling system. Keep at it and you'll get the air out.
silvia-junkie
Car: s14 kouki
ok i think i know my problem the turbo coolant feed line started to leak prety bad. now do you guys know the eaist way to change it. i have a braided line. should i take the turbo off or can i change it with the turbo on?
thx
