When the fan is just slipping along [when the air blown past the thermosensor is cool enough] you can stop the fan with some difficulty with your hand [don't try this incase your viscous has failed!!!!!!!!!]. As the air gets above 100F this gets harder!
Based on the feel of it I doubt 1-2 HP is being used to drive the fan......now there is some friction added by belts and pullies. The HP requirements increase at the cube of the fan rotation speed but the viscous allows the fan to slip and it appears that the fan never exceeds 2500 rpm:
http://www.hortonsachs.de/sach....html
The problem is high rpm [when the engine is creating 10-15 times more power than at idle or low speed] the electrics can't keep up with the need to spin 5,000 rpm yet the mechanical isn't efficient enough at 650 rpm idle but ok at 1500-2000 cruise.
'A study of converting all accesories to electric showed that a 300 HP V8 would need 1200 wats for all electric cooling {PEAK} and 400 watts average power consumption'............the alternator only produces 1440 watts at 60 mph and maybe 500 watts at idle.What would the other items like injectors or AC fan run from?
This is why we will be going to 42 volt alternators to triple the available power then everything can be run electrically: brakes, steering, cooling, AC.
In theory the mechanical will last forever except for belts, electric's life is proportional to use.
Guess you could experiment by removing the fan belt or fan [make sure the auxillary electric compressor/overheat fan works] in winter then get it warmed up and measure acceleration 0-80 mph on an on ramp. Normal time is around 10-11-12 seconds.. log a least 3 tries each and average
"An M130 pusher fan measures 15 x 13.5 inches and is only 2.25 inches deep. With a 12-inch-diameter fan turning 2,000 rpm, Flex-a-lite rates the M130 for cooling up to a 125hp engine (100 with air conditioning). That cooling capacity is in addition to stock when used as an auxiliary pusher. " ..............so you need 3 such fans?????
Electrics work quite well on 100-150-even 200 HP engines just not on 300HP engines with smallish radiators.
Coolant capacity is an excellant guide to how well things are designed....our 10.5 quarts pales in comparison to MB/BMW/Audi 14-15 quarts for the same power ratings.
Just like rotors over design is good!
