542keith »
https://forums.nicoclub.com/542keith-u56564.html
Mon Apr 23, 2007 7:31 am
Just wanted to get back to you and let you know fixed my problem. I know it's been a while but, better late than never!
It must have been running hot all the time and that's the reason the fan ran more often than usual. It would be 60 degrees outside and I could sit at a red light and the fan would come on. Funny though, the temp gauge never moved beyond the middle.
I swapped out the thermostat, flushed and filled with Prestone 50/50 premix, burped the system and everything is cool now. Now the fan only comes on when I have the A/C or defrost on. That's the way it ran when I first bought it. Still the temp gauge stays in the middle. I guess if the temp gauge goes up then there's something really bad going on.
Apparently, the type of radiator made no difference.
