Cooling Fan
IanS13
does any one make a direct bolt on cooling fan for the 240sx.
Structure240sx
what do you mean like an electric fan? many will "bolt" right on. you jsut need to wire them up
IanS13
yes were can i buy one. you guys have any recomondations
Modified by IanS13 at 2:45 AM 11/15/2004
Mishka
Nissan Altima fan works fine. I just installed one a couple of weeks ago. It was slightly bigger, so you would have to trim it on each side. I got mine from junk yard for 50 bucks.
deCksy
what year altima did you get it off of miskha?
WDRacing
If you want cheap most any set of dual electric fans from a junkyard will work. Just modify the shroud to make them fit.
MikeMurphy
Car: Guess
and lots of zipties! zipties make anything fit!
WDRacing
Zip ties and rivits are an awsome combo...
574-240sx
Car: Nissans, Toyotas, Subaru
Zip ties and a stock GM electric fan worked for me.
