mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Sat Feb 09, 2008 5:32 pm
Going by the wiring diagram definitely a ground trigger from the ECU. What kind of fan(s) are you using?
Looking at how its setup they work it just like the 3rd gen Maxima (and I'm sure other gens and cars). They use two speed fans in the Maxima and turn on one relay for low speed and both relays for high speed.
As in the FSM for the Q, the low speed only occurs when temps are between 203° F and 221°, the car is below 25 MPH, and the A/C is on. In this case relay 1 turns on.
Above 25 MPH and 221° with the A/C on, the fan(s) is on high speed (both relays on).
At any speed if the temp is above 221° and the A/C is off, both relays turn on for high speed.
Now... if you have a regular one speed electric fan I would just hook up both relays to it. This way, no matter what the scenario, the fan will turn on when the ECU tells it to.
