wow glad the dealer "looked into the problem" and found nothing so greedy :cSnake31 wrote:I looked into this some more and found that I was a little low on coolant; it was about 1/4" below the minimum line. I had a slow leak on the top driver side drain plugs after the timing chain recall was performed. I topped it off a while ago but perhaps it needed a bit more. I topped it off tonight but still the fan runs more a frequently and louder than it used to. Upon further inspection, I noticed that the driver side fan does not come on at all . I let the engine idle for ten minutes and still no driver side fan.
Snake31, since the timing chain debacle I have had a lot more noise (high pitched whine) in the cooling fan(s) and it seems to be on more than usual. What ever happened with your car? When you replaced the module did the fan behave normally?Snake31 wrote:Today I swapped the driver-side and passenger-side cooling fan control modules with each other and the driver-side fan now works and the passenger-side does not. I have ordered a new module from rock auto. If any of you guys notice your fan making more noise than usual, more often than usual, then check that both fans are turning on as they should.
Snake31 wrote:Yes it is much quieter now that I've replaced the cooling fan module...
