loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sun Jan 31, 2010 1:33 pm
Which Maxima model year?
Cooling Fan Relay 1 is used for Low Speed Cooling while Cooling Fans Relays 2 and 3 are for High Speed Cooling. The ECM controls the ground (Pin 2) of the relay to turn it ON/OFF depending on the coolant temp, speed, and AC status.
Most likely you have a stuck (close) Cooling Fan Relay 1 (for low speed cooling) causing both fans to run at Low Speed with Ignition ON. Another possibility is that Pin 2 of the relay is shorted to ground or the ECM is continuously grounding it. Also possible is defective Coolant Temp Sensor causing the ECM to turn on the cooling fans.
Pull out Cooling Fan Relay 1 and the fans should turn off. Replace as required. Verify Pin 2 of the relay receptacle is not grounded. If so, you may have a problem with the harness, ECM or coolant temp sensor.
