Cooling fan activation temp?
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
2013 AWD S. Coolant temp hits over 205 and cooling fans do not kick in, but they run if I turn on the AC. I thought they were supposed to kick in over 195F? Is that normal? It's never overheated BTW.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
No, with the AC off the fan should be kicking on low speed at 208F, high speed at 212F. You can find the charts on EC-74 here:
https://www.nicoclub.com/service-manual ... 3%2FEC.pdf
You can check both speeds of the fan using the IPDM auto-active test. The temp reading goes straight to the ECM, so if what's coming out of your scanner seems accurate, the sensor is fine.
phmichel
VStar650CL wrote:
Sat Feb 03, 2024 6:44 am
Thanks VStar - as always...
VStar650CL
Technical Expert
:dblthumb:
Return to “Rogue Forum”
