Cooling duct block off or scoop?
DETurbine
Car: Nissan S13 RB25
Just finding ways to cool down my RB. I have heard of some people ducting their 240sx correctly with block off plates on the top and bottem of the opening between the bumper and radiator to direct the air flow into their radiator without flowing out. Not sure how well that works with those people not running the 89-90 bumpers that have a fmic like me that is covering the whole opening of the bumper, blocking all of the air flow coming in.
I have also heard people making a scooped ducting plate for the bottom of their car allowing air to be pulled up and into the radaitor.
Just seeing if anyone has had any luck with any.
thanks
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
i used a street sign thats bolted to my subframe it runs from the inside of the front bumper all the way to the transmission, and i have a cooling plate on top of my rad. sort of helped, if your having cooling issues and are thinking this will help you need to start with a n1 water pump , after market rad, cooling flush first
DETurbine
SullivanRacing06 wrote:i used a street sign thats bolted to my subframe it runs from the inside of the front bumper all the way to the transmission, and i have a cooling plate on top of my rad. sort of helped, if your having cooling issues and are thinking this will help you need to start with a n1 water pump , after market rad, cooling flush first
Just looking for every little thing to help. Running about 195-210f right now on a week that days are mid to high 90's and humidity is about as high as you can get. If I can get it down to 180-190 I will be happy. This is on a fresh rebuild, so no flush is needed. I have only bled it once, so am bleeding it a few more times tonight and moching up some ducting work. If this doesn't work I am stepping up to 12'' fans.
I was just curious about which is working better for people. A scoop design duct on the bottom pulling the air up towards the front of the radiator or completely blocking it off with a plate on the bottom and top allowing the moderate air flow that is passing through the front already to be directed into the radiator.
julio
Car: RB26 AWD converted S14
Dual core and stock clutched fan ftw if you can manage it. My temps don't see anything above 180* even on a 90*+ day.
SullivanRacing06
i have a koyo with a factory clutch fan and shroud in my r32 and the temps i listed are with the koyo and clutch fan n shroud
DETurbine
alright. thanks for the input thus far. I have seen people have great results with the stock clutch fan. I will have to see if I can squize the clutch fan up front. Not sure if I am going to be able to, runnign stock R33 crossmember and have a koyo.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I use 1/2"foam weather stripping to get a complete seal of my radiator to the AC condenser. My 12" SPAL fans are mounted as pushers to the front of the AC condenser. If there is a gap between the radiator and fans, the air will not go through the core effectively. It will simply go around it. Ducting is extremely important for cooling system performance. What fans are you running right now? Anything less than FAL or SPAL and it is probably doomed to failure from the get-go.
Neejay
Darius wrote:I use 1/2"foam weather stripping to get a complete seal of my radiator to the AC condenser. My 12" SPAL fans are mounted as pushers to the front of the AC condenser. If there is a gap between the radiator and fans, the air will not go through the core effectively. It will simply go around it. Ducting is extremely important for cooling system performance. What fans are you running right now? Anything less than FAL or SPAL and it is probably doomed to failure from the get-go.
Where'd you get that foam weather stripping?
eh?
Run a clutch fan. Even without the shorud mine runs cooler than with fal 220's. One of the best changes I ever did.
imotion s14
Car: 1997 240SX
I did the same as Darius, I got mines at walmart.
Shocker
Car: 89 240sxHB rb26/30
eh? wrote:Run a clutch fan. Even without the shorud mine runs cooler than with fal 220's. One of the best changes I ever did.
You running a stock rad? Did you cut/move your core support forward?
eh?
No I'm using a koyo with an S14 fan and I had to cut the support.
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Can someone please explain what all the hype is with clutch fans?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Keeps the temps down really good that's what the hype is.
