andauto »
https://forums.nicoclub.com/andauto-u26424.html
Sun Mar 06, 2005 8:03 pm
I just bought a 1995 240sx base model. I was told that the A/C was removed for weight reduction. The car keeps overheating or at least the gauge needle goes past the "H" when the heat is off or very low. When I turn the heat up, press A/C button and send fan to 3 or 4 temp gauge goes back to "normal". On cold starts in the morning I sometimes have to give it a little gas to start. I think its only the thermostat, but not quite sure.The car has these other problems/flaws as well if anyone can help w/ those it will be greatly appreciated. By the way I did search for the cooling a lot but nothing seemed like mine.Driver's window does not operateDoor locks from outside do not operate well (pass. does not operate at all), from inside there are no probs. Wondering if I get alarm would there be probs or should I get shaved door handle kit?A dent in fender but I will be doing a conversion so i will leave that be
