coolest temperature sensor
Jbuck
Car: 2000 Infiniti QX4
Having a hard time finding the coolant temperature sensor. Code po115.
I replaced the coolant temperature sender unit above the thermostat single wire. But where the hell is the coolant temperature sensor?
2000 QX4
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Page EM-10 of the factory service manual has an exploded view of component parts on the engine.
https://www.nicoclub.com/service-manual ... 0%2FEM.pdf
It looks like the ECT sensor is mounted into the water outlet pipe at the front of the engine, which is also where the thermal transmitter is located.
Jbuck
Thanks I found it.
