cooler lines under the intake
IanS13
what's the easy way to get to the cooler lines under the intake manifold.i got one that's starting to leak before it blows out i want to replace it.
also my front timing cover seal went out leaking like a motha does the crank pully just slide off on our cars or does it need to be pulled with a puller.
PapaSmurf2k3
Site Admin
your probably going to want to pull the intake mani... i know, it sucks, but sometimes it just has to get done. As far as the crank pully, mine was a bisnitch, but i think i ended up just pounding it off with a hammer. A puller would be best.
IanS13
damn i guess am going to be pulling my intake damn it.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
the frickin intake mani sucks big time. it was a pain in the *** when the motor was out of the car. Hopefully you won't have any headless bolts in yours.
IanS13
cooler line fixed turns out it was the trottle body cooling/heating return line from TB to intake manifold it was easly repaired by removing the altenator looks like the oil from my leaking crank seal, broke down the cooler line turning it soft and brittle, the crank seal was no problem i just used a 24" long braker bar and hit the key simple as pie.
