kawboy12 wrote:Has anyone tried to install a coolant temp. "gauge" on a Versa 1.8,or does anyone know if there is a warning bell,or buzzer installed from the factory.I'am just not crazy about where nissan put the warning light.Maybe it's just me,but the way i sit in the driver seat,i can't see the coolant temp. warning light in my normal driving position.I'm sure i would see it at night,but 80% of my driving is daytime.If there is no bell,or buzzer,I would be very interested in installing a gauge.Any info on this would be appreciated."Thanks".
You might want to consider a Scanguage. Runs about $150, gives you all the information you want about your engine. Plugs right into the OBD port, and gives you real time information regarding water temp., voltage, rpms, fuel milage, and a host of other bits of helpful information. It also can read and cancel most error codes.
http://www.nissanraceshop.com/product/3 ... OgodUAsArA
