Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Feb 12, 2004 10:45 am
The only thing that counts is how what the ecu reads . The amount the resistance gets translated into a coolant temp by the ecu.
The inside gauge is so damped [slow moving and slow to change] that it is almost useless, except for reading: cold, warm/ok, and hot.
95% of the 6-7 year old Q I see are always above ideal temperature due to lack of maintenance and the slow progressive build up of dirt ,oxidation, fin bending, rubber surround deterioration.
Many non oem aftermarket radiators look the same but are low cost copies which may only work 90% as well as new oem, this coupled with therostats , cracked fan blades, sloppy installation, and engine coolant passage build up means the head temperatures may be hotter than designed even though the coolant temp may read normal.
