95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Tue Jan 03, 2006 5:50 am
BTW, all of the following is in regards to the coolant temperature sensor that feeds to the ECU, not the temperature indicator sender which drives the needle in the dash.
i've searched and i've talked to my local SR shops (XAT and Enjuku) and everybody seems to agree that in order to get the car running properly, a JDM Redtop coolant temperature sensor is required. XAT said that they've had mixed results with USDM KA sensors. i went to XAT to get the very last of their stock of the JDM CTS and what do you know, they told me they'd be open Jan 02 2006, but nobody was there. another guy with S15 SR + S13 5-speed into S14a trailered in from jacksonville, and me and him both go screwed b/c XAT was never open. we both were told they'd be open and apparently we were lied to. thanks, guys.
anyways, i went to the nissan dealership and found that the CTS is the same for all pre-OBD-II 240SX's 1989-1996. so i figured that if the KA24E, KA24DE/S13 and KA24DE/S14 all shared the sensor, the Silvia/180SX w/ SR20DET probably shared it as well. i didn't check if Z32's use it as well, but i would guess it's likely.
i know i was told the results were mixed, but i bought the sensor straight from the dealership for $25, installed it [with a little trouble because my 19mm deep socket apparently isn't that deep], and it's been running in tip-top shape since. thanks for nothing, XAT, and to the rest of you, good luck. when this sensor goes it's a beeotch, running really poorly once warmed up, ultra-rich, missing all over the place and lacking a lot of power.
