coolant temp sensor.
T88lexus
ok.. I need coolant temp sensor for my car... do you guys know which sensor will work? KA, SR, ca18et or anything...
I have two KA one so I ma try but if guys know which one works for sure.. let me know..
thank you for all your help and appriciated
rico05
Car: 1992 RMS13 w/ CA18DET
I just went into O'Reilly's and said I needed a temp sensor for a 1988 Pulsar SE w/ CA18DE. $22 later I had a working sensor
T88lexus
so any ca18de sensor will work?can I just buy it from the any auto store? napa and others.. thanks
boost_boy
Answer is yes!
Dee
T88lexus
thank you dee
I have another question.
I have a troble hooking up the o2 sensor..it is generic bosch 3 wire sensor2 white and 1 black.. black is for senderwhites are 12v and/ground..
when I hook it up.. it will stumble and cut off. unhook it runs 100 time better than hooked up.
I am thinking I have problem with wiring... or someithng. because o2 is brand new. old one or new oen doesnt make any differncewhat do I need to start to trouble shoot..
kinda related to this.. my car runs horrible on partial thorttle... runs perfect on WOT. boost and no hesitation at all...but on partial throttle .. especially on very little throttle.. it feels like cuts off and clugged.. untill you give more gas and it start to take off.. I dont think its MAF because it runs great on WOT. I also have good compression as well.
let em know what u think
boost_boy
You definitely have the wires hooked-up wrong, but I can't say too much about the bosch O2 sensors.
Dee
iliketocrash
so what is a good "stock" equivalent that can be had stateside for the ca18det?btw, whatever happened to the crossover parts sticky?
F3600
300ZX twinTurbo or Na is not okay ? i remember hearing about that somewhere
pulsar gtr
Car: NISSAN VEHICLES
I am using the 300zx z32 O2, it is the same one and will plug in without any mods, both twin turbo or N/A have the same part #.
Regarding your generic O2, the black is the signal which goes to a white wire on your CA harness, then the O2 got 2 white wires, one is 12v and the other is ground, doesn't matter which is which,
PULSAR GTR
drftnassmofo
Car: 84 s12 ca18et-TRADED
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
90 coupe KADE swap-SOLD
06 Infiniti M45
if your car starts sputtering and sometimes stalling while at a stop light or a start up or something..basically just not when its WOT then start your car and wiggle the mafs connector..it worked for me..then i thought it would be all corroded or dirty or something so i took it apart and it was spotless it still gets loose every once in a while since i took it of
T88lexus
nahh. MAF is good.. getting good contact, getting correct V to the MAF.
it was o2. I just used the Z32 o2 sensor worked fine..
float_6969
Just to clarify, you did get it working correctly by using the Z32 O2 instead of the generic, right?
T88lexus
yap
Projex240
Car: Dogs , My RIDE
Good thread, and good info. That helps me out with making more notes in my little black "journal" that ill refer to when my install almost definately ****s up on me.
