coolant temp sensor
september
Car: 1991 240sx
hey what's up, I replaced my cts but I'm still getting code 13. I checked the harness for the ecu, the wire is def plugged in. I replaced it with a brand new sensor from autozone so it should be good. I checked the harness that connects to the sensor while the car was running and it was picking up signal on the multimeter. does this sound familiar to anyone?
DemonicSpeedz
Car: 1995 240sx se
reset ur ecm
september
Car: 1991 240sx
unplugged the negative and positive leads to the battery today when I woke up. came home from work about 6-7 hours later and hooked the battery back up. Still getting code 13 my car is an s13, the previous owner replaced the radiator with an s14 radiator, and he def did some custom wiring. would this cause code 13 even though the sensor is fine? I'm at a loss here, thanks for the help.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
strip the harness back. remove all the split loom and trace the harness all the way to the ecu. look for damaged/frayed wires, make sure its wired right
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
Check the CTS harness for voltage.. reset the ECU manually using the dial on it
september
Car: 1991 240sx
yeah that was it, didn't realize you could reset the ecu that way still have code 34 though, but that's a different story for a different day.
