Postby
rudee023 »
https://forums.nicoclub.com/rudee023-u4970.htmlFri Feb 04, 2005 6:32 pm
I have a redtop SR. I know the SR replacement list says that I should use the CTS for a 95 KA24DE but was wondering if there was a difference between S13 and S14. Also I heard people run B13 SE-R sensors. Are they all the same?
Postby
pgt892 »
https://forums.nicoclub.com/pgt892-u2513.htmlSat Feb 05, 2005 10:19 pm
Yes, there is a difference between the S13 and S14. I was having issues with my CTS and was told that the CTS needs to match the chassis year and not the motor year. Apparently, the S14 gauge cluster needs a different voltage than the S13 CTS sends.
Postby
rudee023 »
https://forums.nicoclub.com/rudee023-u4970.htmlSun Feb 06, 2005 3:29 pm
I think you are talking about the thermal transmitter for the gauge cluster if you are running an S13 SR in an S14. I am talking about the CTS that sends the signal for the ECU.
Postby
pgt892 »
https://forums.nicoclub.com/pgt892-u2513.htmlMon Feb 07, 2005 11:07 am
rudee023 wrote:I think you are talking about the thermal transmitter for the gauge cluster if you are running an S13 SR in an S14. I am talking about the CTS that sends the signal for the ECU.
