FDR Dippin »
https://forums.nicoclub.com/fdr-dippin-u43490.html
Wed Oct 22, 2008 3:26 pm
Can a bad coolant temp sensor cause LOTS of fuel filled white smoke? Reality is i've prayed and tomorrow is in God's hands! I trust i didn't just sacrifice my Q!.
The cost of doing an injector and plug job, just wasn't sitting well with me, I was quoted $2700 and just couldn't rationalize it, as much as i like and need my car, that was simply unreasonable to me!
So I purchased a set of plugs from joe and a set of advertised NEW! OEM purple tops from EBAY and payed a shop to put them in. When i picked up the car, i immediately realized the vibration or shakes i was feeling was still there. I also smelled fuel which i guess i expected considering the job. Well, i pulled off and PUFF and cloud of trailing smoke consumed the car behind me. I drove about 1/4 mi to see if it would blow out and had to turn around. WHAT did i do? Rather what did they do? or WHAT did i buy? What's causing this?The shop pulled the plugs to see if any were wet and ALL on the side they pulled were wet. They think they installed all o rings OK and think it unlikely the damaged ALL.So.... they check MAF...OK. They scanned ECU and said they had coolant temp sensor hard code!No check engine light and no noticeable high idle. Could this be the cause of EXTREMELY rich fuel mix? Before this job, i never saw smoke from my car... by the time most of you read this it'll be morning and FEDEX would have delivered the sensor and it'll be put in. But tonight, i just wonder could this possibly have coincedentally gone bad or did the shop f-up the injectors and/or plugs?
