Coolant temp sensor location
sr20detmaybe
Car: 95 240sx
where is the stock coolant temp sensor on a s14 sr? thanks. I searched and couldnt find the answer.
wildacexxx
Car: 2002 Q45 nav sport
should under the fuel pressure regulator. theres to connectors down there. one is for the ecu and one for the cluster. the biggest one is for the ecu
180fan
Car: 89 fastback
follow the lower radiator hose to the elbow. you'll find the two wire and single wire coolant temp sensors there.
sr20detmaybe
Car: 95 240sx
thanks all
