Coolant Temp Sensor Location in KA24E
Altiman94
Car: 1989 Nissan 240SX
I was told my bobbing idle is caused by a faulty coolant temp sensor in my ka24e. I would liek to know where this is located (the one for the ecu, not the gauge cluster). They have the part in stock at Advanced Auto. I just wanna know where this is before I start the job. Thanks in Advanced.
NISTECH
red or yellow 2 wire connector near the t-stat housing on the intake manifold.
Altiman94
thank you NISTECH.
Altiman94
do I need to bleed the cooling system of air after I replace the sensor?
NISTECH
acrually if you do not remove the rad cap and the car was not just shut off from running(after it has sat a few mins). you can remove it and put it back in with out loosing a drop.
Altiman94
sounds good, that's what I was hoping for.
240sx88
Car: 1990 nissan 240 sx
is it under or above the intake?
benemorius
Car: s13, s13, eg, e36
It sits right smack on top - conveniently ready for plucking.
240sx88
I found it. 1.) does it take about a 19mm socket, and 2.) i know my ecu ain't throwin a code by my idle bobs up and down and i get bogind and hesitation sometimes. even tho i ain't throwin a code can it still be bad or gunked up?
