1990 to be exact. please helpsliksta1 wrote:i did already tried to bleed the cooling system through that little bleeder hole , unless i didnt do it right, which is always a possibilty. all i did was add coolant to the radiator until it started coming out of that bleeder hole, anything im missing here. my car is a s13 with a red top in it, also do you think that if the thermostat is stuck it would cause this problem.
