not true, they are the exact same sensor.240life wrote:If you had a sohc or dohc prior to installing your sr, you will need to install the sensor from that motor on your sr in order to make your gauge read correctly.
you got it backwards the two wire is for the ECU and the single wire is for the Gaugeredsx13 wrote:
There are Two coolant temp sensors, one for the ecu and one for the gauge, the one for the gauge is the one with two wires going to it, replace it and you may just find that it fixes your problem.
ya i noticed that, the two pronged is the more important one anyway.Sileighty_85 wrote:
just get a Defi System and glue the needle in the middle haha
The stock Gauge is a useless POS
What? I don't think so.240life wrote:If you had a sohc or dohc prior to installing your sr, you will need to install the sensor from that motor on your sr in order to make your gauge read correctly.
How is this true if I have an s14 sr in an s13 and my temp sensor reads fine.bruinbear714 wrote:Do you have an S13 chassis or S14? the dash sensor is dash cluster specific.
S14 cluster => needs temp sensor from S14 engine.
S14 dash temp sensor..
S13 dash temp sensor.
I know for a fact you can't mix different chassis with different engine years without the temp gauge cluster going whacked, because I ran into the EXACT same problem a few months back while replacing the dash sensor and coolant. Dash read HOT five minutes into starting the engine.Stripes wrote:
