coolant temp gauge
jmhalder
Car: base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
so i have a 95 s14, for the past ~8months or so, the temp gauge would shoot down about 1/3 of the way when revs exceeded ~3500 or so, maybe lower... which was fine, because i was always able to confirm the temp over bikirom, or consult... now it has completely stopped working all together, and the needle is on "C" and wont move... is this a common problem, is there a common solution... how would one suggest i fix this?
steve s14
it's most likely the coolant temp sending unit, the one with the single wire.the one with the 2 wires next to it is the coolant temp sensor for the ecu, that's not the one for the gauge.the riveted blade connector always comes loose, solder or try and lightly hammer the rivet snug again. replace it with a new one if you don't want to attempt fixing it or deal with problems if the fix doesn't last.
da40
Car: 1995 SE 240sx
mine did that and i switched to the ka sensor and it started reading right again,before it say it was reading hot but i would check the motor,and hoses and everything would be fine,thats what i did to solve my problem
