what brand ? the autometer sender is rather lengthy, it should still be inside the coolant neckfloat_6969 wrote:I had trouble with mine as well. The problem was that the threads were SOOO close to the same size that I couldn't find an adapter that would read the temps right. The problem I ran into was that the sensor was so far up away from the coolant due to the adapter that it was very slow to react.
I ended up drilling and tapping a new hole.
ill will update when i get it.... autometer brand adapter with autometer sender should work just fine, otherwise i will return it and tap a new hole.. but, i do not use the stock gauge cluster so id rather just remove the sensor and put it there with an adapterfloat_6969 wrote:I'd like to know. IIRC I think you're going to be disappointed in your adapter. I hope for your sake I'm wrong. It's been a while since I messed with it, but I remember having problems with it. That's why I ended up just drilling and tapping a new hole.
crap... i thought it was 1.25, but yeah all they have is 1 and then 1.5The_Chosen_One wrote:I was in the same boat as you.
Unfortunatly Autometer doesnt sell the adaptor size you need because they are fools.
The correct size for that sensor is M12x1.25 to 1/8 NPT I know this because I purchased a Greddy adaptor which is for oil pans and fits that sensor location perfectly.
Unfortunatly the greddy adaptor only works with Greddy sensors as the autometer one is too big.
I dont know why your stud didn't fit most likely it wasnt the right size possibly a M12x1.5. But if you want to truly test it, take your oil drain plug out and screw it in that hole it should thread on.
If you like I can provide a pic of said adaptor, I still have the stock sensor in because I havent purchased a greddy gauge cause their a complete rip off but am forced to purchase one soon.
The greddy sensor should work perfectly as I'm sure its long like the coolant sensor next to the one your refering to.
Here is a link to said adaptor.
http://www.speedtechnique.com/....html
the gauge temp sensor thread IS M12, i know it looks smaller, i thought it was going to be 1/8 bspt or something.float_6969 wrote:There is now way that adapter will work. That thing is WAY too big. I think you're thinking of the ECU temp sensor. He's talking about the gauge cluster temp sensor.
and why doesnt the autometer probe fit in that ? Is the hole going through it too small?The_Chosen_One wrote:No I was refering to the cluster sensor its a M12x1.25
The coolant sensor for the ECU is M12x1.75. Nissan enjoyed using wack thread sizes to make life more difficult.
Anyways are some pics I just took.
uh obviously it isnt even hooked up yetSil40sK wrote:Sorry to threadjack but how's that short sweep oil pressure gauge working for you? I was contemplating getting one of those (as opposed to saving for defi, apexi, blitz, hks, omori, or high end autometers) but I've heard they're rather slow to respond since they arn't stepper motor and therefore by the time the gauge tells you something's wrong you're already screwed. I've never seen them in action and I'm going to be road racing this next season (since my car will finally be running) so I don't want an inaccurate gauge.
cut out all the guts of the stock cluster.. and on the black piece leave a small edge all around it ... and then cut out a piece that fits in it and epoxy'd it inrico05 wrote:No info for ya that hasn't been covered, but thanks for the pic. I am now 100% sure that I will be swapping my stock cluster out for the setup you have there. Very nice. Mind tell us how you did it? Did you paint and cut a stock cluster? Thanks man.
why tap a new hole when there is an existing one that is not in use?sideways danny wrote:I just drilled and tapped my stat housing, much easier.
I can probably do that, Im going to do them shortly, I woke up a little late.The_Chosen_One wrote:If you do get them to work I have 2 that I want to send to you. The only thing I'm worry about is that possibly it might be weak.
Either way if you do lathe it down and it fits nice definatly would like you to do 2 for me.
