Coolant
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
mrlovalova
Car: Infiniti EX35
How often should you be filling the coolant tank on the EX35?....seems this coolant tank is often empty quickly.
Any info is appreciated.
NJGuy
Car: 2008 Infiniti EX35 Journey AWD
You shouldn't be refilling the coolant overflow tank or radiator at all, as the cooling system is supposed to be sealed. Your EX definitely has a leak somewhere if you have to keep topping off the coolant.
mrlovalova
Car: Infiniti EX35
Thanks for the reply....I think so too but the thing is I cannot find even a spec of fluid leaking anywhere so I'm kinda confused lol
NJGuy
Yeah, sometimes these slow leaks are hard to find. Actually, be happy that the leak is slow; at least it gives you a bit of time to plan out a repair and you have a smaller chance of your car breaking down mid-drive.
There are a couple of things you can try to help find the source of the leak: a pressure test of the cooling system, or putting in a coolant dye in the system. The dye appears under UV light, so you'd need to shine a UV blacklight around the cooling system for the dye to show itself.
mrlovalova
Car: Infiniti EX35
You are absolutely correct..I notice that there is liquid present when I'm starting up the car especially when its cold..will investigate where its coming from. Thanks much.
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
did your radiator spring a leak?
mrlovalova
Car: Infiniti EX35
Yep it was the radiator that was leaking...brought it to the dealer..a $1300 dollar job...thank goodness for the extended warranty :)
carldu
Car: 08 Titan
$1300 for a radiator? I think that's too pricey.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
