kouki-gymkhana »
https://forums.nicoclub.com/kouki-gymkhana-u9464.html
Sat Jan 27, 2007 9:43 am
You should perform a leakdown test. I had a blown HG with no obvious signs (ie white smoke out the exhaust or bubbles in the coolant). Given what you have described, it sounds like you do not have adequate flow through the radiator, either because the thermostat is still faulty (even though you've said you already replaced it), the Koyo is blocked (unlikely since it's new) or the waterpump is toast. Unfortunately, it looks like you're going to have to pull things apart to see what's really going on. You could try removing the thermostat altogether and see what happens after a test drive. That would at least let you rule in or out the thermostat as the culprit.
Good luck and keep us posted. BTW, as you've already pointed out, you should NEVER rely upon the stock temp gauge because it is incredibly inaccurate. I was seeing 85 degrees C on the highway with a blown HG and the stock gauge was reading "C" the whole time.
