Coolant System Validation Test - Milestone Complete
OwnerCS
This evening I installed the radiator and completed a coolant system pressure check. The caps started releasing pressure at approximately 15 lbs. maximum. It is still maintaining 13 lbs after 30 minutes. Now it is time to move on the plenum assembly and vacuum lines.
Here's a picture of the pressure test below.
