coolant system???
sydwayz
Car: 1992 nissan 240sx
does anybody have a graph on how the stock coolant system (coolant lines) is hooked up or at least if anybody could show me how they have there coolant system (coolant lines) hooked up???
biosehnsucht
sydwayz
nice now how bout a way so i dont have to have the throttle body hoses and heater hoses or the ones right under the throttle body hooked up or is this to ghetto
biosehnsucht
Use your imagination. Where it would T to /from the heater or to/from the TB, just don't.
jt15833
Car: 95' 240SX
How necessary are the two hoses that connect to the back of the intake manifold, near the firewall?
Hoses 14056+C14056+Don biosehnsucht's first link
I got rid of the throttle body circulation but these two seem like they could be removed for the same reason, unless they help cold start issues substantially.
biosehnsucht
The car would run without them, they're used to help warm up the intake manifold (similar to the hoses for the TB). It probably wouldn't have much effect to remove them in a warmer climate, but if you were say in Canada then you might be better leaving them. When the air coming in is too cold, the fuel won't atomize properly.
