Coolant smell
BreEzy2121
Car: Infiniti M45 Sport
I changed my coolant and after I was done I could smell coolant when my m 45 was running I pressure washed the engine bay and still smelled it I checked over everything I have no leaks I don’t understand why I still smell coolant any help would be great Also does any one have any good parts I can buy for my 08 infinity m45 Sport that will give me solid hp gains
Ilya
Did you look under the car or just from the top? It may be dripping somewhere where you can't see it but not hitting the ground either.
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
Regardless..that smell lingers for awhile.
Aztectech
Car: 2007 Infiniti M35
Mine smelled too. Pin hole leaks at high pressures will aerate a coolant leak so you will get all of the stink and no obvious leak. Get some fluorescent dye and a black lamp (any auto parts store will have these) pour the die, run it, and this works best in a bit of darkness, flash your black light ( I got a cheap pen one) I recommend splurging the xtra 5 bucks and getting a solid black light pen because then you can use it to look for other leaks using dye like engine oil or refrigerant.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Aztectech wrote:
Fri Mar 12, 2021 9:46 am
Good advice.
BreEzy2121
Thanks guys I will get the dye. The smell has gotten less and less So will see I do have one other question what tool do you guys use to get the back bolts off the valve cover Saying it’s tight to work in there is an understatement
EniGmA1987
Car: '06 Infiniti M35 Sport
BreEzy2121 wrote:
Sat Mar 20, 2021 3:41 pm
I dont recall any special tools I used. I believe it was always just a socket wrench, and sometimes with a long extension on it.
LIBRILZ
2007 M45 Sport
Remove your battery, theres an access hole from the firewall to get to them
